How We Tested
As of our GTX Titan review, we've updated our GPU test rig. It's now equipped with the multi-GPU powerhouse that is the
Asus Maximus V Extreme, allowing us to run up to 4-card SLI and CrossFire with 8x PCI-E 3.0 lanes per card.
We've also updated the CPU to an
Intel Core i5 3570K running at 4.2GHz to raise the CPU headroom, and paired it with 8GB of 2,400MHz Corsair Dominator DDR3.
The chassis has also been upgraded to NZXT's
Switch 810, a case big enough to house even a pair of Asus' Ares 2 graphics cards. Powering that many graphics cards has also required a replacement power supply with the Lepa G1600 1600W PSU offering more wattage and 8-pin PCI-E power connectors that we'd ever need.
Our benchmarks now include figures for Bioshock Infinite but otherwise remain the same mix of custom in-game time demos and manually-played sections, using FRAPS to record the average and minimum frame rates. We strive to not only record real-world performance you will actually see, but also present the results in a manner that is easy to digest. We test at 1,920 x 1,080 (1080p), 2,560 x 1,600 and 5,760 x 1,080.
Test System
- Intel Core i5 3570K (operating at 4.2GHz – 42 x 100MHz)
- Asus Maximus V Extreme motherboard
- 2 x 4GB Corsair 2,400MHz DDR3 memory
- Lepa G1600 1600W PSU
- Windows 7 Home Premium 64bit
- Samsung SSD 830 256GB SSD
AMD graphics cards
- AMD Radeon HD 7990 6GB (1,000MHz GPU, 6GHz memory) (Catalyst 13.5 beta)
- AMD Radeon HD 7970 3GB GHz Edition (1,000-1,050MHz, 6GHz memory) (Catalyst 13.4 WHQL)
- AMD Radeon HD 7950 3GB with Boost (875MHz-925MHz GPU, 5GHz memory) (Catalyst 13.4 WHQL)
- AMD Radeon HD 7870 2GB (1,000MHz GPU, 4.8GHz memory) (Catalyst 13.4 WHQL)
- AMD Radeon HD 7850 2GB (860MHz GPU, 4.8GHz memory) (Catalyst 13.4 WHQL)
- AMD Radeon HD 7790 1GB (1,000MHz GPU, 6GHz memory) (Catalyst 13.4 WHQL)
- AMD Radeon HD 7770 1GB (1,000MHz GPU, 4.5GHz memory) (Catalyst 13.4 WHQL)
- AMD Radeon HD 7750 1GB (825MHz GPU, 4.5GHz memory) (Catalyst 13.4 WHQL)
Nvidia graphics cards
- Nvidia GeForce GTX Titan 6GB (836Mhz, boosting to 876MHz, 6GHz memory) (GeForce 314.22 WHQL)
- Nvidia GeForce GTX 780 3GB (836Mhz, boosting to 876MHz, 6GHz memory) (Launch Driver - GeForce 320.20 beta)
- PNY GeForce GTX 770 XLR8 OC 2GB (1,150MHz, boosting to 1,202MHz, 7.2GHz memory) (GeForce 320.49 WHQL)
- Nvidia GeForce GTX 770 2GB (1,046Mhz, boosting to 1,085MHz, 7GHz memory) (Launch Driver - GeForce 320.20 beta)
- Nvidia GeForce GTX 760 2GB (980Mhz, boosting to 1,033MHz, 6GHz memory) (Launch Driver - GeForce 320.39 beta)
- Nvidia GeForce GTX 690 4GB (915MHz, boosting to 1,084MHz, 6GHz memory) (GeForce 314.22 WHQL)
- Nvidia GeForce GTX 680 2GB (1,006MHz, boosting to 1,110MHz, 6GHz memory) (GeForce 314.22 WHQL)
- Nvidia GeForce GTX 670 2GB (915MHz, boosting to 1,084MHz, 6GHz memory) (GeForce 314.22 WHQL)
Nvidia GeForce GTX 660 2GB (980MHz GPU boosting to 1,033MHz, 6GHz memory) (GeForce 314.22 WHQL)
- Nvidia GeForce GTX 650 Ti Boost 2GB (980MHz GPU boosting to 1,033MHz, 6GHz memory) (GeForce 314.22 WHQL)
- Nvidia GeForce GTX 650 Ti 1GB (925MHz GPU, 5.4GHz memory) (GeForce 314.22 WHQL)
- Nvidia GeForce GTX 650 1GB (1,058 MHz GPU, 5GHz memory) (GeForce 314.22 WHQL)
